MiniSearch widget doesnt work execSearch()
6379
44
07-05-2010 05:40 AM
NatashaManzuiga
http://forums.esri.com/Thread.asp?c=158&f=2421&t=295623#953276
I have the same problem...execSearch()..in MiniSearch widget.
If I add a search term and press Return nothing happens. I also added a button to the widget with the "execSearch()" statement and nothing happens with this either.
Thx
Naty
AlexJones
Thanks I will keep my eyes open for it.
NatashaManzuiga
Alex, I m so sorry I m still out from my office ... but I will come back to work in 3 days...so I will send what u need...if u still need as soon as possible....
Have a great day.
Natasha
NatashaManzuiga
Wowwwwww
Thank u so much Robert!!!
Naty
Hi Robert Im trying to migrate my miniSearch widget from 1.3 to new 2.4 version of the viewer...
Did u upgrade it?
Naty
RobertScheitlin__GISP
Naty,
   If I remember right you mad a lot of changes after I posted the miniSearch so it might be better if you post what you have in 1.3 and I will see about upgrading it. Don't forget to send your actual searchWidget mods too.
NatashaManzuiga
Naty,
Hi Robert, I m using Autocomplete too..so I post u what I have. 🙂
Thank u so much Robert 🙂
Naty
Naty,
   Are you sure this is the right code?... Most of the code that does anything is commented out?...
NatashaManzuiga
Naty,
I m so sorry I'm soo busy today and I made a mistake..
This is the version that is working in my SFV 1.3
I m so sorry...u wasted ur time for me 😞
After I modified it...what should I do in index.mxml ?
Naty
Naty,
   I have to ask again if this is the right code it is hard to believe that you are using something that looks like this:
[ATTACH=CONFIG]8383[/ATTACH]
NatashaManzuiga
Naty,
Robert Im really sorry, I checked it 3 times....and it was the correct one...
Now I m sending u again the right code.
Sorry,
Naty
Naty,
   Here is your MiniSearch updated to a Flex Viewer 2.4 actual widget.
Also I forgot to mention in the readme.txt that the widget has to go in the UI section at the top of the config.xml like the NavigationWidget.
