Map services blocked by FireFox but Not IE
1270
08-01-2012 10:38 AM
ShaningYu
Honored Contributor
I am working on a ArcGIS Flexviewer project.  The map services (including ESRI's basemaps) display well on IE but got blanked in Firefox.  What's the possible reason for it?  Thanks.
ShaningYu
Honored Contributor
It was one of my old threads.  The problem got solved a long time ago.  It was a proxy issue.
RhettZufelt
MVP Notable Contributor
I have seen this issue when the data is accessible only to users on a domain.  IE passes your domain credentials to the web server, Firefox does not.
At least in the past it worked this way.  Our IT guys had us remove Firefox and only use IE for "security" reasons so I can't test it ?????
R_
Drew
The best way to debug the problem would be to use FireBug or Fiddler to see what the tiles are coming back as.. 404 Errors, 403?
ShaningYu
Honored Contributor
