Make a Cadastral web application
893
06-19-2012 01:07 AM
ShayanNikoohemat
I want to make a web application with cadastral data (including farms, canals, owner and crops). My web application should be server side and have below functionalities:
1- get information/ measure and simple controls
2- classification according crops
3- layer on/off
4- search for a special owner name
5- edit owner table
6- marker clustering
7-draw polygon
Is it possible to develop these functionalities in flex, if not which other web server services of ArcGIS you recommend?
Many thanks.
AnthonyGiles
Honored Contributor
shayan.ni
You should have no problem creating a web application in flex that meets your requirements, most of the functionality you are after is included in the sample viewer. Editing would require that you have a minimum of server v10.
Not quite sure what you mean by classification according crops, do you mean applying a unique value render i.e.
http://resources.arcgis.com/en/help/flex-api/samples/01nq/01nq0000006z000000.htm
Regards
Anthony
