local map services do not display in flexviewer
830
09-07-2010 01:31 PM
MarkTownsend
Hello. I cannot get a local map service to display using the Flexviewer 2 application, either the compiled or uncompiled version. The simple map service I'm trying to display is http://www.stjoemap.info/ArcGIS/rest/services/Mark/MapServer. I've tried other local map services and they won't display either. However, it does display correctly if I create a web app using arcgis server. It also displays correctly in a simple Flex app using the ArcGISDynamicMapServiceLayer tag. Any ideas why the service won't display?
Thanks.
Mark
DasaPaddock
Are you running the Viewer from http://www.stjoemap.info/...? If not, you'll need to put up a crossdomain.xml file at: http://www.stjoemap.info/crossdomain.xml
See References at http://help.arcgis.com/en/webapi/flex/help/index.html
MarkTownsend
Thanks. I have it working.
