Loading Layers to be buffred widget point buffer
794
03-13-2014 03:43 PM
fatizanady
hello everyone,
I want to apply buffer to my layers using a geoprocessing service.i'm bloked in loading a layer (points) that well be buffered.
I'm trying to do that but the following error appears:
"Call the push method may not defined through a reference type static com.esri.ags.layers:FeatureLayer."
I need really your help, i'm new to Flex so I'm sure that there are multiple errors but would like to know if I'm going about this the right way? Thanks for any help that could be offered!
this is the code:
<?xml version="1.0" encoding="utf-8"?>
<viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009"
       xmlns:s="library://ns.adobe.com/flex/spark"
       xmlns:mx="library://ns.adobe.com/flex/mx"
       xmlns:esri="http://www.esri.com/2008/ags"
       xmlns:viewer="com.esri.viewer.*"
       xmlns:components="com.esri.viewer.components.*"
    <fx:Script>
        <![CDATA[
   import com.esri.ags.Graphic;
   import com.esri.ags.Units;
   import com.esri.ags.events.GeoprocessorEvent;
   import com.esri.ags.layers.FeatureLayer;
   import com.esri.ags.tasks.supportClasses.LinearUnit;
   import mx.controls.Alert;
   import mx.managers.CursorManager;
   import mx.rpc.AsyncResponder;
   private var dist:LinearUnit = new LinearUnit();
   private function executer():void
    var haslayerSelected:Boolean = (map.defaultGraphicsLayer.numGraphics > 0);
    var hasSelectedLayersTobebufffred:Boolean = pointsCheckBox.selected  ;
    if (haslayerSelected && hasSelectedLayersTobebufffred)
     buffer();
    else
     showErrorMessage("Select layer to be buffred");
   private function showErrorMessage(content:String):void
    Alert.show(content, "Geoprocessing Task Error");
   private function buffer():void
    var requestObject:Object = createRequestObject();
    gp.execute(requestObject);
    CursorManager.setBusyCursor();
   private function createRequestObject( ):Object
    var layersToBuffred:FeatureLayer = getLayersTobebuffred();
    dist.distance = Number(bufferDistance.text);
    dist.units = "esriMeters";
    var requestObject:Object = {
     " GPBuffer_DBO_points ": layersToBuffred,
     "Distance_ ": dist
    return requestObject;
   private function getLayersTobebuffred():FeatureLayer
    var layersToBuffred:FeatureLayer=new FeatureLayer;
    if (pointsCheckBox.selected)
     layersToBuffred.push(pointsCheckBox.label);
    return  layersToBuffred;
    </fx:Script>
<fx:Declarations>
  <esri:Geoprocessor id="gp"  url="http://localhost:6080/arcgis/rest/services/Geotraitement/edatazip/GPServer/edatazip"/>
</fx:Declarations>
    <viewer:WidgetTemplate id="wTemplate"
                           width="244" height="209">
  <s:Label x="47" y="43" text="Séléction couche"/>
  <s:CheckBox id="pointsCheckBox" x="52" y="72"/>
  <s:Label x="86" y="72" width="91"/>
  <s:Button  x="87" y="174" label="Executer" click="executer()"/>
  <s:TextInput id="bufferDistance" x="123" y="114" width="60" paddingLeft="5" paddingRight="0"
      text="100"/>
  <s:Label x="48" y="123" text="Distance"/>
    </viewer:WidgetTemplate>
</viewer:BaseWidget>
