Legends not showing in Internet Explorer 8
6196
12
04-09-2012 07:06 AM
ionarawilson1
I have a Flex Application that works great in Internet Explorer 9 and Firefox. However with Internet Explorer it does not show the colors for the legends, just the values. Do you guys could give me any ideas  what I need to change in my code so that IE 8 shows the legend colors? You can see on the image attached that the colors show correctly on the map but the legend does not show the colors for each values.
I am attaching the mxml and the html and the print screen. Many thanks!!![ATTACH=CONFIG]13340[/ATTACH]
by Anonymous User
Not applicable
Original User: ionara_wilson
I found a solution! I went to the flash player security settings and added the folder I had the data and the problem was solved. So I think the legend problem appeared just because the website has not been published on the web yet. I hope it helps anybody with the same problem.
by Anonymous User
Not applicable
Original User: suhana
Hi, can you elaborate a little on this please.
I am having similar problem where in internet explorer 8, the legend does not show for secured map services which use arcgis server token security through proxy.ashx and I am using java script api.
ionarawilson1
Hi Suhana
I found the legends were not showing when I was accessing the app from my local server (computer), but when I published in the real production server the legend was there. I think to make it work on your computer you have to go here:
http://www.macromedia.com/support/documentation/en/flashplayer/help/settings_manager04.html
And add the folder where your project is so the flash player regocnizes the drive and  folder. It worked for me. Good luck!!!
