is it possible to fit the legend into a fixed frame using print widget and custom tem
2108
06-12-2013 11:50 PM
BartBajek
does anyone have experience with trying to fit the legend of the WebAPI (Flex) into a fixed frame when exporting the map to a pdf? I am using a custom template to export my map and I just cannot get the legend being dynamically resized to a fixed frame that is set in my template for the legend. Anyone any suggestions or has done this before? Any help would be appreciated. I am using ArcGIS Server 10.1 and the template.mxd is saved as a 10.1 version as well.
Cheers
Bart
BjornSvensson
Esri Alum
I think that you can setup that on the Legend Element�??s Properties page in ArcMap.
[ATTACH=CONFIG]25366[/ATTACH]
