Is Design View Supported for Map?
823
12-01-2010 01:43 PM
RoyceSimpson
I thought this was fixed upon 2.0 release but Map doesn't seem to be compatible with Design View again.
I'm using SDK 4.1, API 2.1.
-Royce
DasaPaddock
Yes, it should be working with Flash Builder 4. What part isn't working for you?
RoyceSimpson
Not sure the cause, but if I create a new Flash Builder project/application, add a map instance and go to Design View, it works.
The problem must lie somewhere in my current project which is upgraded/imported from an api 1.3/sdk 3.5 project.  I am using 2.1 api and 4.1 sdk so I'm not sure what details under the hood are borked.
It definitely only occurs in components that contain a Map instance.  Odd.
I'll try to look into it as time permits.
