Infowindow on service with raster?
863
11-20-2013 06:52 AM
ionarawilson1
Is there a way to create a infowindow or pop up for a feature or map service that has a raster? If so, can you please send me a link to a sample or code snippet? Thanks!
AnthonyGiles
Honored Contributor
Ionara,
You should be able to identify a map service with a raster using this sample:
https://developers.arcgis.com/en/flex/sample-code/identify-features.htm
A raster will probably only return the pixel value at the point
Regards
Anthony
ionarawilson1
Thank you so much Anthony!
