InfoPopUp widget with multi layers?
1252
12-14-2010 05:55 AM
RichardHolloway
Is it possible to add more then one layer as a feature layer?  I also don't understand what the config-map.xml would be used for?  Currently I have one feature layer working but not sure how to add another feature to the list from another layer.
BjornSvensson
Esri Alum
Yes, you can add multiple layers of type 'feature' in the main configuration file (config.xml).
config-map.xml is just another example of a main configuration file.
RichardHolloway
Ok.  Trying to get the darn sde server to work.  May have to have sqlexpress reinstalled.
RichardHolloway
Oh...one other question.  I found the link to the NCSU Wolfline Transit Visualization System http://ncsu.transloc.com .  Is what they did put feature layers in the actual Layers widget to make them selectable and unselectable?
