Incomplete geodatabase from extract data task
808
01-06-2012 10:54 AM
ronaldmcfarlane
When I use the extract data widget, the downloaded Gdb file does not include the "timestamps" nor "gdb" files and thus is not recognized by ArcGIS as a Gdb. If I copy the two files over from a blank Gdb then everything works fine. Any clues why an incomplete Gdb is shipping?
Using ArcGIS Server 10 and Flex 2.4.  This is a cross post from the ArcGIS Server - .NET Forum
ronaldmcfarlane
The "Extract Data" widget (Flex API) extracts the data, writes the GDB, zips it up and sends it to the user's identified location.  I still don't know what the problem was/is, but it now works most of the time without any fixes.  I guess it is a black-box error/fix.
