identify widget with image...and hyperlink
3515
16
06-21-2010 01:43 AM
DavideRodomonti1
Hi all, is there a widget that shows in the identify tool an image and a hyperlink?
I wish I could do it.... :))
Thanks to everybody
David
SandeepTalasila
It worked. Thank you so much Robert.
SandeepTalasila
Hi Robert,
Sorry if I am asking too many questions, am still learning. I was trying to add text in the info popup window and identify window, for the attributes with url's saying that 'click on the link...'. I was able to do that, but the text is showing up even for the layers without any url. I was not able to figure out how to relate the text with the link. Could you please help me with this.
RobertScheitlin__GISP
Sandeep,
   You need to attach the code for where you added that text in the InfoPopupWindow.mxml.
SandeepTalasila
I am sorry for forgetting to attach the code.
Sandeep,
   Here is the fix.
SandeepTalasila
Thank you Robert, It worked. I have missed adding 'infolinkTitle' in if(infoData.link) function.
All,
   A new version of the identify widget is now available.
* 2.2.3 - Identify by point/line/extent/polygon are all now supported
- Info window will appear at the center of identified geometry now if returngeometryforzoom is set to true in xml file.
if returngeometryforzoom is true, when you mouse over a record the geometry for that particular record is drawn using the symbology defined in the xml
- The symbology used by the draw tools is now user defined in the xml
- Fixed an issues with link icon if prefix or suffix is supplied and a empty field.
