I don't know why happen these error
1618
08-06-2012 02:37 AM
daewoongkim
HI, I have learned about API for Flex3.0 to ready project.
I'm using flex builder version 4.1 and API Flex for 3.0
(in fact, I downloaded Flexbuilder ver. 4.0. but I know it is version 4.1 after install my PC)
I'm training output map (sample : http://resources.arcgis.com/en/help/flex-api/samples/index.html#/Tiled_Map/01nq00000058000000/
but,
there are 9 errors.
Description Resource Path Location Type
1046: Type was not found or was not a compile-time constant: Form. BAAF  Unknown Flex Problem
1046: Type was not found or was not a compile-time constant: FormItem. BAAF  Unknown Flex Problem
1046: Type was not found or was not a compile-time constant: FormLayout. BAAF  Unknown Flex Problem
1046: Type was not found or was not a compile-time constant: GestureEvent. BAAF  Unknown Flex Problem
1046: Type was not found or was not a compile-time constant: Image. BAAF  Unknown Flex Problem
1046: Type was not found or was not a compile-time constant: TransformGestureEvent. BAAF  Unknown Flex Problem
why not T^T
(I'm already import these constants, but these problems are not solved. )
MostafaFouly
close all the opened tabs, the projects then close flash builder.
after start flash builder again and open the desired project then clean all the projects (project --> clean --> clean all projects).
it sounds weird but sometimes it helps!
DasaPaddock
You'll need to use Flex SDK 4.6.
