How to re-design the header bar -- v 2.1
1523
12-08-2010 08:51 AM
GeorgiannaStrode
I'm trying to re-design the header bar, with no luck.
I want do not want to show logo, title, or subtitle but instead move the widget container to the left.
Any ideas on where to look?
Thanks in advance.
BjornSvensson
Esri Alum
Remove logo, title, subtitle from your config.xml.
To align the widget icons to the left, go into HeaderControllerWidget and change the "center" below to "left" (at least that's what I think you are trying to do):
<mx:HBox id="widgetBox"
          width="100%"
          horizontalAlign="center">
RobertScheitlin__GISP
Georgianna,
Sure that is pretty easy just see the required changes below:
<mx:Image id="logoIcon"
                      horizontalAlign="left"
                      maxHeight="{headerContent.height}"
                      maxWidth="80"
                      verticalAlign="middle"
       visible="false" includeInLayout="false"/>
            <s:VGroup id="titleGroup"
                      height="{headerContent.height}"
                      gap="0" visible="false" includeInLayout="false">
                <s:Label id="bannerTitle" styleName="BannerTitle"/>
                <s:Label id="bannerSubtitle" styleName="BannerSubtitle"/>
            </s:VGroup>
                     width="100%"
                     horizontalAlign="left">
WallaceBezerra
What do you mean about "re-designing" the header bar? Do you want to build a completely different one? Want to customize the existent widget?
GeorgiannaStrode
Thanks everyone!  I love it when simple code works the first time.
The widget buttons are left-justified!
GeorgiannaStrode
Wallace, I want to keep the same one just left-justify the buttons.
