How to load aerial basemap layers dynamically?
1312
04-04-2013 11:36 AM
ShaningYu
Honored Contributor
Last year when I worked on a Flex project, I loaded Robert's wonderful component eMapSwitcher (http://forums.arcgis.com/threads/621...d=1#post214917).  Now in my new project, I want to use the tool's transparent slider feature for 2 selected basemaps (1 being the street map, and another is a selected aerial map) only.  All of the basemap layers are listed in the config.xml.  What is the proper way to load the aerial basemap layers dynamically?  My plan is to have a control to select an aerial map.  Then, I can open the BaseMap widget, which shows only the streets and the selected aerial map.
Another option is for the loaded aerial basemaps, I can select one to activate it.
Then I can apply the transparent slider for the 2 basemaps.
Thanks if you can provide your idea.
RobertScheitlin__GISP
Shanning,
   this is now possible using the latest eMap Switcher widget.
Version 3.2.1 - April 8, 2013
* Added drag and drop re-order capability to the basemap switcher (Thumbnails ONLY).
ShaningYu
Honored Contributor
As the continuation of my post above, is it possible to dynamically changed the order of the loaded basemaps?
Shanning,
GISDev1
It seems your Esri Forums "Points" hit the 32-bit limit!
4294967295
Cool!
