How to find Parcel_ID(Parcel_Number) from URL
5502
12
06-22-2013 10:29 PM
Bakht_AliMohammad_Khan
Hello All,
          I want to find Parcel_Number and Subdivision_Number from url address in Flex web maps like this
www.abc.com.index.html?parcel_Number=23&Sub_Number=55
                                       Thanks in advance.
Bakht Ali
AnthonyGiles
Honored Contributor
Bakht Ali,
A 400 error on this widget means that the query you are trying to use is invalid, have you set up the configuration file to work against your layers?
Regards
Anthony
Bakht Ali,
Regards
Anthony
Yes the configuration file is set. Even if we not change the esearch url link it work successfully but when we give link to our local GIS SERVER in esearch cods as was shown in jpg send before, then esearch not working & give this error.
it means we have to change something in esearch codes?
Bakht Ali
AnthonyGiles
Honored Contributor
Bakht Ali,
The search will work against the layers online as it is set up to work with those layers, if you want it to work against your own services/data then you will need to set up the config file to your services, have a look at the set up help file:
https://github.com/rscheitlin/eSearch/raw/master/Enhanced%20Search%20Widget%20XML%20Configuration.pd...
Regards
Anthony
