How to customize my navigation ?
1412
05-30-2010 12:43 AM
__1
when i click the "plus" button,it shows "zoom in",and when i click the "minus" button,it shows "zoom out".
can you help me how to override the componet to let it show other words.
RobertScheitlin__GISP
jmuguy,
   Here is a sample.
The Application:
<?xml version="1.0" encoding="utf-8"?>
<mx:Application
 xmlns:mx="http://www.adobe.com/2006/mxml"
 xmlns:esri="http://www.esri.com/2008/ags">
 <esri:Map id="map" navigationClass="com.esri.ags.samples.MyNavigation">
  <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer"/>
 </esri:Map>
</mx:Application>
The MyNavigation.as File
package com.esri.ags.samples
    import com.esri.ags.controls.Navigation;
    import mx.core.UIComponent;
    import mx.controls.Spacer;
    public class MyNavigation extends Navigation
        public function MyNavigation()
            navigationSliderClass = MyNavigationSlider;
        override protected function addZoomInZoomOutComponents(
            zoomInButton:UIComponent,
            zoomOutButton:UIComponent
        ):void
         zoomOutButton.toolTip = "zoom way out";
         zoomInButton.toolTip = "zoom way in";
            addChild( new Spacer());
            addChild( zoomOutButton );
            addChild( zoomInButton );
MattiasEkström
Where should I put this code if I want to use it in the Sample Flex Viewer 1.3?
Or is there another way to change the tooltips?
I want to change the dataTip of the slider too.
Mattias,
   If you look at the MyNavigation.as it starts out with package com.esri.ags.samples, this is where you need to put it. You will have to create a ags and a samples sub folder in the com esri folder structure. Then in MapManager
//Add this import
import com.esri.ags.samples.MyNavigation;
//in the config function add
map.navigationClass = MyNavigation;
Then add this to the com.esri.ags.samples folder
The MyNavigationSlider.as File
// ActionScript file
    import com.esri.ags.controls.navigationClasses.NavigationSlider;
    import com.esri.ags.layers.LOD;
    import mx.controls.sliderClasses.SliderDirection;
    public class MyNavigationSlider extends NavigationSlider
        override protected function formatDataTip(value:Number):String
            var result:String;
            var lod:LOD = map.lods[value]; // get the LOD for the given level
            var scale:Number = lod.scale;
            if (scale < 10000)
                result = "Neighborhood";
            else if (scale < 100000)
                result = "City"
            else if (scale < 1400000)
                result = "County"
            else if (scale < 5000000)
                result = "State/Province"
            else if (scale < 20000000)
                result = "Country"
            else if (scale < 50000000)
                result = "Region"
            else if (scale < 100000000)
                result = "Continent"
            else
                result = "World"
            return result;
MattiasEkström
Thanks again Robert! We can always count on you 🙂
There was just a small little problem, the zoom in och and zoom out buttons switched places. The zoom out was over the slider and zoom in under, which didn't make any sens, but it was just to switch the code in MyNavigation.as were the components are added.
So if anyone else reads this thread and has the same problem here's the MyNavigation.as code with the tiny modification:
  ):void
