How to convert X/Y to lat/long
84328
04-12-2013 06:46 AM
ShaningYu
Honored Contributor
For a MapPoint, I get its X/Y coordinate values.  How can it be converted into lat/long values?  Thanks.
RobertBorchert
Honored Contributor
IF you already have it in ArcMap simply create a new x,y fields (lat long)  and use the right click on one of the new columns and select Calculate Geometry.
If you don't have it in ArcMap use the X,Y to create the features and then do the above.
AnthonyGiles
Honored Contributor
Shaning,
It depends what coordinate system your application is in. If you are using web Mercator there is a class, see here:
http://resources.arcgis.com/en/help/flex-api/apiref/index.html?com/esri/ags/utils/WebMercatorUtil.ht...
If you are using anything else you will have to do the math yourself or use your geometry service.
Regards
Anthony
Drew
If you are just looking to convert coordinates as a widget, I made one a little while ago.
You can download it here:
http://www.arcgis.com/home/item.html?id=edd4a2b7c722493a8b08f53eaa131e1e
If anything you can dig through it and use it as a code sample.
Drew
RobertBorchert
Honored Contributor
ShaningYu
Honored Contributor
Using the CoordinateMenu component and revising a couple of functions, I made conversion very well.  Thanks.
omega_cancer
Call a simple function:
myMP=map.toMapFromStage(X,Y);
