How to add a MapMouseEvent?
801
06-27-2012 05:32 AM
ShaningYu
Honored Contributor
I want to add a MapMouseEvent in ActionScript.  The code I created is below:
  map.addEventListener(MouseEvent.CLICK, myEventHandler);
  private function myEventHandler(e:MapMouseEvent):void {  ... }
But I received TypeError: Error #1034: Type Coercion failed: cannot convert flash.events::MouseEvent to com.esri.ags.events.MapMouseEvent.
How can this bug be fixed?  Thanks.
KenBuja
MVP Esteemed Contributor
Instead of adding the MouseEvent.Click event, you should add the MapMouseEvent.MAP_CLICK event
KenBuja
ShaningYu
Honored Contributor
Thanks.  It works.
