How to add a default value to object while using editor
1066
12-25-2011 10:38 PM
hanwang1
Dear esri flex team
I meet a problem when I use editor to add a new object through feature service.
when I add a new object on map through editor,after editing successfully,it will pop up an attribute window for editing its attibutes,there is one field storing date data,I want this field could be filled up automatically by current date,how can I do this?
thanks in advance
Han
RobertScheitlin__GISP
Han,
   Look at this post and the whole thread will be helpful. Understand that this is not simple or for beginners.
http://forums.arcgis.com/threads/19995-Easiest-way-to-customize-AttributeInspector-associated-with-a...
nanzhang
Maybe you can set a default value for every field when you edit the feature layer template in ArcMap. Then,republish your feature service.
