Help with widget configuration files
2392
09-09-2011 04:05 PM
RickGeittmann
I have a question if there is a site or document that provides some detailed documentation for figuring out the various widgets configuration XML files for the various widgets. As a non programmer I usually can figure out from examples and in conjunction with some programming book get sorted out. I have a basic API up and running using 2.4 but have not been able to get some of the widgets to work such as the TOC or Legend widgets. I have searched through the forum but have not found any info other than the default information. Any help would be greatly appreciated.
We are running Server 9.3.1
Rick
RobertScheitlin__GISP
Rick,
  Sure there is specific documentation for each widget and the Flex Viewer has it's own specific forum (which is where you should post Flex Viewer and or Widget Questions).
Flex Viewer Forum:
http://forums.arcgis.com/forums/111-ArcGIS-Viewer-for-Flex
Flex Viewer Documentation:
http://help.arcgis.com/en/webapps/flexviewer/help/index.html
RickGeittmann
AHA!! Thanks Robert - the link to the FLEX specific forum section thins down the amount of threads to search through for info and looks like some of the specific stuff I am looking for is located there.
Rick
