GraphicsLayer has minimum supported version of 4.0 which is higher compatibility 3.0
863
10-13-2010 03:39 AM
PrashanthSukumaran
We are in the process of migrating our GeoApp from Flex 3 to Flex 4 and Flex API for ARCGIS 2.1.  We would like to keep the changes to minimum and also take the advantages of the new Flex API for ArcGIS 2.1.
We have enabled the "Flex 3 compatibility mode".  This is throwing the
The dependency com.esri.ags.layers.GraphicsLayer from C:\....\flex_libs\agslib-2.1-2010-09-17.swc has a minimum supported version of 4.0.0, which is higher than the compatibility version, 3.0.0. BaseWidget.as /GeoApp/flex_src/com/esri/solutions/flexviewer.
Is there a way around this.  We have a lot of Flex Code.
If i uncheck/unselect the "Flex 3 compatibility mode", do i have to do a lot of changes to take advantages of the Flex 4 and ArcGIS Flex 2.1
