GraphicLayer not displaying resulting FeatureSet
1277
11-16-2010 11:39 AM
RickBaker
I am attempting to display the results of my featureset in the GraphicsLayer but nothing is displaying. I know the query is working because of the count on the features in the resulting featureset.
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
 xmlns:s="library://ns.adobe.com/flex/spark"
 xmlns:mx="library://ns.adobe.com/flex/mx"
 xmlns:esri="http://www.esri.com/2008/ags"
 pageTitle="Salt Lake County Recorder">
 <s:layout>
  <s:VerticalLayout gap="10"
   horizontalAlign="center"
   paddingBottom="20"
   paddingLeft="25"
   paddingRight="25"
   paddingTop="20"/>
 </s:layout>
 <fx:Script>
 <![CDATA[
  import com.esri.ags.Graphic;
  import com.esri.ags.FeatureSet;
  import mx.controls.Alert;
  import mx.rpc.AsyncResponder;
   private function doQuery():void
   queryTask.execute(query, new AsyncResponder(onResult, onFault));
   function onResult(featureSet:FeatureSet, token:Object = null):void
    // No code needed in this simple sample, since the
    // graphiclayer is bound to the query result using
    // graphicProvider="{queryTask.executeLastResult.features}"
   function onFault(info:Object, token:Object = null):void
    Alert.show(info.toString(), "Query Problem");
 </fx:Script>[/INDENT]
 <fx:Declarations>
  <esri:QueryTask id="queryTask"
   showBusyCursor="true"
   url="http://<mydataurl>/MapServer/4"
   useAMF="false" />
  <esri:Query id="query"
   outSpatialReference="{myMap.spatialReference}"
   returnGeometry="true"
   where="PARCEL like '%{qText.text}%'">
  <!--<esri:Query id="query"
   text="{qText.text}">
   <!--where="PARCEL like '0827131011%'"-->
  </esri:Query>
  <esri:InfoSymbol id="infoSymbol1">
   <esri:infoRenderer>
    <fx:Component>
     <mx:VBox>
      <mx:Label text="{data.PARCEL}" />
      <mx:Label text="{data.own_name}" />
     </mx:VBox>
    </fx:Component>
   </esri:infoRenderer>
  </esri:InfoSymbol>
 </fx:Declarations>
 <s:Panel
  height="60"
  title="Query a layer (search parcel number)"
  backgroundColor="#ECE7E7">
  <s:layout>
   <s:HorizontalLayout/>
  </s:layout>
  <s:TextInput id="qText"
   enter="doQuery()"
   text="0827131011"
   width="100%"/>
  <s:Button click="doQuery()" label="Do Query" />
 </s:Panel>
 <esri:Map id="myMap" >
  <esri:ArcGISDynamicMapServiceLayer url="http://<mydataurl>/MapServer" />
  <!--<esri:GraphicsLayer id="myGraphicsLayer" symbol="{infoSymbol1}" />-->
  <esri:GraphicsLayer id="myGraphicsLayer" symbol="{infoSymbol1}" graphicProvider="{queryTask.executeLastResult.features}" />
 </esri:Map>
</s:Application>
DasaPaddock
What happens if you don't set myGraphicsLayer's symbol? Can you also double-check that the layer's shape field is published so that the geometry is being returned?
RickBaker
Yes, that worked! I removed the GraphicsLayer symbol setting and now I see the graphic layer displayed in the apparent default symbol. Apparently something wrong with my "infoSymbol1" definition??
thanks for the help,
Rick
DasaPaddock
The InfoSymbol only works with point data. Are you returning polygons?
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/symbols/InfoSymbol.html
