Graphic Layer Shifting and Map Click Location Offset in Flex API 2.0
3127
07-29-2010 05:03 AM
RafaelFerraro
I have recently switched from Flex API 1.3 to 2.0, and am seeing a number of issues.
First, I have a geoprocessing service (9.3.1) that returns a feature layer to be drawn at the client.  When I start zooming out, the graphic layer starts shifting south.   When I start zooming in, the graphic layer shifts north back to its original position.
Second, the mapPoint registered for a mapClick event seems to be offset.  For example, I will initiate an event at an intersection, and the results get drawn a significant distance south of the intersection.  I have a feeling this might be related to the first issue.
I never saw these issues with the 1.x API's.  Anyone see something similar, or have any idea of what might be causing this behavior?
RafaelFerraro
For anyone who cares, this behavior only occurs when the map is accessed from a module.  If I perform the same actions in the application containing the map, everything works as expected.
