Google Maps Tiles
950
10-08-2012 10:17 PM
StuartThomas
I see this question has been asked a few times - nothing for a while though - can google maps tiles be loaded using ArcGIS flex API?
Providing there's a way to pass a Google Maps API key - surely this can be done?
MarcinDruzgala
Ok since I've searched a lot about google maps in flex applications I might help you a bit.
Here you have some links:
1.http://forums.arcgis.com/threads/51953-Google-Maps-in-Flex-Viewer  -read all
2.http://forums.arcgis.com/threads/20871-Google-Street-View-Widget-for-the-Flexviewer/page2  -read post #63 and #64
The quick answer is, sadly, NO you can't use google maps in flex application. The next thing i thought a bit is that if it wasn't illegal ESRI programmers would implement google maps in ArcGIS Viewer for Flex - it's not hard to get these maps in Flex app thanks to Javascript function. Google does not longer supports Flash developers - you can't get new Google Maps API key for Flash, only Javascript developers are welcome.
Hope this helps. If you'll find something that deny what I've said please let me know!
Cheers,
MDruzgala
StuartThomas
Thank you Marcin - very good of you to dig these up.  I had found the first post but not the second - like you said, seems to be a resounding no.  I'll post back here if I find a solution to this.
