getting a Credential object using IdentityManager and ServerInfo
3644
11
08-14-2012 03:32 PM
DirkVandervoort
The code below fails with the error message. How do I get the credential based on my token service URL?: TIA
faultCode:null faultString:'Error #2032: Stream Error. URL:https://gis.blahblahblah.com/arcgis/tokens?tokens' faultDetail:'null'
     var serverInfo:ServerInfo = new ServerInfo();
     serverInfo.tokenServiceURL="https://gis.blahblahblah.com/arcgis/tokens?tokens";
     IdentityManager.instance.generateCredential(serverInfo, myStupidUserName, myStupidPassword, new AsyncResponder(credentialResponse, credentialFault));
DasaPaddock
Try setting the tokenServiceURL to the same as what you see on your server at /arcgis/rest/info
e.g.
http://sampleserver6.arcgisonline.com/arcgis/rest/info
DirkVandervoort
That does not work.
It returns the mx.RPC.Fault message of:
faultCode:null faultString:'Error #2032: Stream Error. URL: https://gis.blahblahblah.com/ArcGIS/tokens' faultDetail:'null'
I'm on AGS 10.03 if that's any help.
DasaPaddock
Can you use HttpFox to see what the requests and responses are?
DirkVandervoort
It's an AIR application, but I ran Fiddler (should have thought of that in the first place!). The returned message in plain text is:
{"error":{"code":499,"message":"Unauthorized access","details":[]}}
This is weird, because those are the same credentials I use getting the token using an HTTPService (mx.rpc.http.HTTPService.HTTPService).
Could it be my firewall? I will test again from outside the firewall later...
DasaPaddock
What was the request for this response? If the response code is 200, then this response should not be generating a "Error #2032: Stream Error".
DirkVandervoort
Oops, my mistake. The Unauthorized access error was from trying to load the map.
The POST result trying to get the Credential is: 405 (Method Not Allowed)
DasaPaddock
DirkVandervoort
Try setting the tokenServiceURL to:
https://gis.blahblahblah.com/ArcGIS/tokens/generateToken
No, sorry.
The returned content:
405 - HTTP verb used to access this page is not allowed.
The page you are looking for cannot be displayed because an invalid method (HTTP verb) was used to attempt access.
DasaPaddock
Are you able to generate a token from the HTML form at:
