get rid of a layer in a map without deleting it in server?
2274
10
01-14-2011 12:37 PM
GeorgiannaStrode
A quick question:
How can I get rid of a layer in a Flex application(not to show up), but keep it in the map server and ArcMap software?
I think it might be some codes in config.xml file, in these following lines:
<map>
<operationallayers>
   <layer url="..." />
        </operationallayers>
    </map>
probably I can add some lines such as <exclude .. >
Anyone having any ideas on that? Thanks in advance
DasaPaddock
If the layer type is dynamic, arcims or wms, you can set the visiblelayers in the layer tag to only the layers you want to be on.
See:
http://help.arcgis.com/en/webapps/flexviewer/help/layer_tag.htm
GeorgiannaStrode
I used to write codes like:
<layer label="Control Points" type="dynamic" visible="true" alpha="1"
   url=".../MapServer" />
and this enabled me to have assess to all the layers in the mapserver.
Now that I tried:
   url=".../MapServer/1" />
    <layer label="Control Points" type="dynamic" visible="false" alpha="1"
   url=".../MapServer/2" />
but in this way no layer come out. Is there anyway to split these layers up and set the visible attribute of them separately?
DasaPaddock
You can control which layers are visible in the service like this:
   url=".../MapServer" visiblelayers="0,1,2" />
GeorgiannaStrode
actually the difference made by
is just to choose which layers to be on, and which to be off by default. I want those layers to not just be off, but not in the list at all. But for some reason, I dont wanna delete them in the server and ArcMap.
DasaPaddock
This isn't currently supported. It would require customization to the TOC component inside the com.esri.viewer.components.toc package.
RobertScheitlin__GISP
Dasa,
   So you guys have no plan to add layerDefinitions support to applicable layers in the viewer?
DasaPaddock
Dasa,
You can set a definitionexpression on a "feature" layer, but we haven't had requests to add support for this to the config for "dynamic" layers. Would you have a use for this? I don't think it would help with what I think Georgianna is looking for.
Dasa,
   OK, thanks for the info I just thought that if the layer had a layerDefinition then the toc would honor that as well and not show the other layers of the map service.
GeorgiannaStrode
Since it's not supported, I gave up the trying on that. Thanks for telling me. But that feature might be really helpful if it is supported someday
