Get position of markers
1801
6
06-04-2014 10:57 PM
SamarthGupta
Hi everyone,
How can i get the position of the markers if the markers are overlapped at certain zoom level. If they are overlapped then i want to show the number of overlapped maker on the marker point or the picture marker.
Is this possible?
AnthonyGiles
Honored Contributor
Sam,
You can add a cluster to a graphics layer pretty easy. Have a look at the attached mxml file
Regards
Anthony
SamarthGupta
Hi Anthony,
I am getting my data from database, and i am getting data in this format and placing them on map like this.
protected function getLocation1_resultHandler(event:ResultEvent):void
 if(event.result.information.rmk != "error")
  filterXML = event.result as XML;
  var testPoint:MapPoint;
  var projParams:ProjectParameters = new ProjectParameters();
  for each(table2 in filterXML.information)
   testPoint = new MapPoint(table2.ax, table2.ay);
   var ptGraphic:Graphic = new Graphic(null, new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 5, 0x0000FF));
   ptGraphic.geometry = testPoint;
   ptGraphic.addEventListener(MouseEvent.CLICK, onClick);
   myGraphicsLayer.add(ptGraphic);
These all mapPoints are in INDIA. How will i use cluster with this code?
SamarthGupta
Hi Anthony,
I have seen some of the examples of using clusters, they are being placed when a feature layer is called.
For example:
<esri:FeatureLayer id="featureLayer"
                           clusterer="{clusterer}"
                           definitionExpression="POP1990 &gt; 75000"
                           mode="snapshot"
                           outFields="*"
                           symbol="{defaultsym}"
                           url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/0">
The URL in this feature layer points to "ESRI_StatesCitiesRivers_USA/MapServer/0". But, i could not find any URL for feature layer which could point out INDIA.
AnthonyGiles
Honored Contributor
Sam,
Regards
Anthony
SamarthGupta
Thanks Anthony,
This has helped in no time.
AnthonyGiles
Honored Contributor
Sam,
Glad I could help, if your question has been answered could you also please check the tick on the post that helped, to mark the question as answered,
Regards
Anthony
