Get Network attributes in Rest service from a flex query
2363
09-21-2011 04:26 AM
carinestolz
Dear all,
I would like to get some Na Server Route details in my Flex website. Is there a function in the Flex api that can helps me in retrieving the details of my Network Analyst Layer, in my REST Service ?
For example, I would like to get the Network Attributes of usage type : esriNAUTCost, using a query like getDetails in the api (see image).
Many thanks for your help,
Best regards,
Carine
AndyGup
@Carine, if you haven't already be sure to check out the samples in the online help, for example: http://help.arcgis.com/en/webapi/flex/samples/index.html#/Routing_around_barriers/01nq0000004m000000...
And, here is the link to the RouteParameters class documentation: http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/tasks/supportClasses/RouteParameters.html
-Andy
Esri Developer Network (EDN)
carinestolz
Many thanks Andy for your reply but this is not exactly what I was looking for.
I am looking for a function that can help me in retreiving from my Flex application, some network attributes in the REST Api.
I would like to find a function like:
var networkLayer= new Layer("my_url.../NaServer")
//make a request on the rest api to get all the details of the NAServer Layer
var details = networkLayer.getDetails()
// in the details, get the network_attributes : I can then get the several cost existing in my Network
var costs=details.network_attributes
Does something like that exists ?
Thanks for your help 🙂
Carine
RobertScheitlin__GISP
Carine,
   Sure you can parse the HTML response yourself in flex. As the values you are after are displayed in the REST endpoint then you can get same in Flex.
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
               xmlns:s="library://ns.adobe.com/flex/spark"
               xmlns:mx="library://ns.adobe.com/flex/mx"
               minWidth="955" minHeight="600"
                creationComplete="application1_creationCompleteHandler(event)">
    <fx:Declarations>
        <!-- Place non-visual elements (e.g., services, value objects) here -->
    </fx:Declarations>
    <fx:Script>
        <![CDATA[
            import com.esri.serialization.json.JSON;
            import mx.events.FlexEvent;
            import mx.rpc.events.FaultEvent;
            import mx.rpc.events.ResultEvent;
            import mx.rpc.http.HTTPService;
            import mx.utils.ObjectUtil;
            private var httpServ:HTTPService;
            private function xmlResult(event:ResultEvent):void
                var Info:Object = JSON.decode(event.result.toString());
                trace(ObjectUtil.toString(Info.networkDataset.networkAttributes));
            private function xmlFault(event:FaultEvent):void
                var sInfo:String = "Error: ";
                sInfo += "Event Target: " + event.target + "\n\n";
                sInfo += "Event Type: " + event.type + "\n\n";
                sInfo += "Fault Code: " + event.fault.faultCode + "\n\n";
                sInfo += "Fault Info: " + event.fault.faultString;
                trace(sInfo);
            protected function application1_creationCompleteHandler(event:FlexEvent):void
                httpServ = new HTTPService;
                httpServ.url = "http://tasks.arcgisonline.com/ArcGIS/rest/services/NetworkAnalysis/ESRI_Route_NA/NAServer/Route?f=pjson";
                httpServ.addEventListener(ResultEvent.RESULT, xmlResult);
                httpServ.addEventListener(FaultEvent.FAULT, xmlFault);
                httpServ.send();
    </fx:Script>
</s:Application>
carinestolz
Many thanks Robert for your reply.
I will use your example to code the function by myself.
Thanks again 🙂
Carine
