flexviewer 2.0 edit widget issue
963
09-01-2010 07:06 AM
SimonMorgan
when trying to use the edit widget, it works when an pp is initially loaded but then will not add further point later. it just says updating as per the attached vdeo. I check server manager and the service it is using has 2 running and 1 in use. the fc in queestion is registed with edits to base.
SimonMorgan
i notice that if I restart the service, it can edit again but it does get gummed up again eventually.
