Flex sample for Reverse geocoding
4086
10
06-22-2010 03:37 PM
VijayashreeN
Hey,
I have 2 questions. I just want to know if the samples that are provided in the ArcGIS resource center are not compatible with flash builder 4. I am  getting lot of runtime errors with those samples. I am a newbie, however with little knowledge I tried to replace wherever mx components are with the latest flash builder components. I am getting run time errors for some. Can any body help me. I am talking about the sample for reverse geocoding. For me it displays the map but it will not display the graphic and the address. It shows a blank window without any address.
I am attaching the file. Can anybody help me please.
Thanks
RobertScheitlin__GISP
V,
    There were three issues in the code.
1. The most important the url to the geocode service was incorrect (GeocodedServer is suppose to be GeocodeServer)
2. import com.esri.ags.tasks.AddressCandidate; is now import com.esri.ags.tasks.supportClasses.AddressCandidate;
3. This line
+ candidate.address.toString() + "\n"
is supose to be
+ candidate.address.Address + "\n"
SreeS
Here is my ReverseGeocode Widget which was developed using Flex 3.2 sdk.
VijayashreeN
V,
3. This line
is supose to be
I did fix the 3 issues. Now my problem is I can display the graphic but no pop up window for the address.  Are there any other errors which I am unable to note?
Also I want to know is there any new version of sampleviewer available?
VijayashreeN
There is a problem with the zip file after downloading. Can you please upload it again?
Thanks
V,
    Does your problem window in Flash Builder not list any issues?
The new ArcGIS Flex Viewer is still not available. It will be announced on the forum when it is available.
SreeS
Thanks
I dont know why I no longer get forum updates to my email.
The previous upload was zipped with WinRar.
Try this one. This ones a regular zip file.
VijayashreeN
V,
Robert,
Thanks for you response. There was no window that was poping up to show errors. However I tried to replace
candidate.address.Address.Address  with candidate.address.Address.toString() + "\n"
Now it shows the address for me. Hope there is nothing wrong with this.
I have a question for you since I see you are the one who is answering most of the questions on this forum I thought you would suggest me something.
I am a student and need to develop a project for a county in NC I have a trial version for 60 days of flex and I am afraid I will not  be able to develop the entire app in this period. Earlier I had an education version in flex 3 now I replaced with this trial version. Since then I wanted to do some customization of sample viewer but when I migrated to flex 4 it is dumping lot of errors. That is the reason I asked you for new version of sample viewer and developers guide.
My question is - Is it a good idea to customize the sample viewer or develop own components.
Thanks once again.
VijayashreeN
No luck. I have Win 7. Unable to unzip the file.
SreeS
Here's the code. Its working on my website.
I still need to test it though. Its been a really long time since i used it.
Try it and let me know how it goes for you.
You can take a look at the working sample under the tools menu: http://www.vahgis.com/flexviewer1.3/index.html
---------- ReverseGeocode.mxml-----
<?xml version="1.0" encoding="utf-8"?>
<BaseWidget xmlns:esri   ="http://www.esri.com/2008/ags"
   xmlns    ="com.esri.solutions.flexviewer.*"
   xmlns:mx   ="http://www.adobe.com/2006/mxml"
   xmlns:maplib  ="com.esri.maplib.*"
   xmlns:widgets  ="com.esri.solutions.flexviewer.widgets.*"
   x     ="600"
   y     ="300"
   widgetConfigLoaded ="init()">
<mx:Script>
  <![CDATA[
   import com.esri.ags.geometry.Geometry;
   import com.esri.ags.geometry.MapPoint;
   import com.esri.ags.geometry.Extent;
   import com.esri.ags.Graphic;
   import com.esri.ags.Map;
   import com.esri.ags.tasks.Locator;
   import com.esri.ags.tasks.FeatureSet;
   import com.esri.ags.events.LocatorEvent;
   import com.esri.ags.events.MapMouseEvent;
   import com.esri.ags.events.DrawEvent;
   import com.esri.ags.layers.GraphicsLayer;
   import com.esri.ags.layers.Layer;
   import com.esri.ags.symbol.PictureMarkerSymbol;
   import com.esri.ags.toolbars.Draw;
   import mx.controls.Alert;
   import mx.controls.TextArea;
   import com.esri.solutions.flexviewer.SiteContainer;
   import com.esri.solutions.flexviewer.utils.WidgetEffects;
   import mx.collections.*;
   import mx.rpc.AsyncResponder;
   import mx.rpc.events.FaultEvent;
      import mx.events.FlexEvent;
   [Bindable]
   private var pointLabel:String;
   [Bindable]
   private var clearLabel:String;
   [Bindable]
   private var descriptionLabel:String;
   private var addressPoint:MapPoint;
   private var zoomScale:Number = 5000;
   private var graphicsLayer:GraphicsLayer;
   private var graphicSym:PictureMarkerSymbol;
   private function init():void
    if (configXML)
     //labels
     pointLabel = configXML.labels.pointlabel || "Point";
     clearLabel = configXML.labels.clearlabel || "Disable Tool";
     descriptionLabel = configXML.labels.descriptionlabel || "Find Address";
     graphicsLayer = new GraphicsLayer();
     graphicSym = new PictureMarkerSymbol(widgetIcon, 20, 20);
     graphicsLayer.symbol = graphicSym;
     map.addLayer(graphicsLayer);
     if (Number(configXML.zoomscale) > 0)
      zoomScale = Number(configXML.zoomscale);
     var url:String = configXML.locator;
    activateTool();
    map.infoWindow.addEventListener(FlexEvent.HIDE, mapInfoWindowHiddenHandler);
   private function mapInfoWindowHiddenHandler(event:FlexEvent):void
    map.infoWindow.hide();
    graphicsLayer.clear();
    setMapNavigation(null, null);
         private function onLocationToAddressComplete(event:LocatorEvent):void
          var candidate:AddressCandidate = event.addressCandidate;
            if (candidate != null && candidate.address)
              var myGraphic:Graphic = new Graphic(candidate.location, graphicSym, candidate.address);
              var text1:TextArea = new TextArea();
               text1.editable = false;
              text1.percentHeight = 100;
              text1.percentWidth = 100;
              graphicsLayer.add(myGraphic);
          text1.htmlText = "<font color='#FFFFFF'>" + candidate.address.KeyField.toString() + "</font> ";    //Street
        map.infoWindow.label = "Address:";
        map.infoWindow.content = text1;
        map.infoWindow.height = 70;
        map.infoWindow.alpha = 0.91;
        map.infoWindow.show(myGraphic.geometry as MapPoint);
     else
         Alert.show("This location does not have a known address.");
   private function onFault(event:FaultEvent):void
       Alert.show(event.fault.faultDetail);
   private function activateTool():void
    var status:String = pointLabel;
    setMapAction(Draw.MAPPOINT, status, drawEnd);
   private function drawEnd(event:DrawEvent):void
    this.showInfoWindow(null);
    graphicsLayer.add(event.graphic);
    addressPoint = event.graphic.geometry as MapPoint;
    locateTask.locationToAddress(addressPoint, 100);
   private function clear():void
   private function widgetClosedHandler(event:Event):void
    clear();
   private function widgetOpenedHandler(event:Event):void
    activateTool();
    graphicsLayer.visible = true;
</mx:Script>
<!-- Start Declarations -->
<esri:Locator id="locateTask"
  url="http://www.vahgis.com/ArcGIS/rest/services/WEB/Address_Locator_MAT/GeocodeServer" concurrency="last"
  locationToAddressComplete="onLocationToAddressComplete(event)" fault="onFault(event)"/>
  <WidgetTemplate id="wTemplate" widgetClosed="widgetClosedHandler(event)" widgetOpened="widgetOpenedHandler(event)">
  <mx:ViewStack id="viewStack" width="100%" height="100%" creationPolicy="all" paddingTop="4">
   <mx:VBox width="100%" height="100%" verticalGap="4" horizontalAlign="center">
    <mx:Text id="txtLabel" text="{descriptionLabel}" styleName="WidgetText" width="100%" textAlign="center"/>
    <mx:HBox horizontalAlign="center" width="100%" horizontalGap="15">
     <mx:Image click="{activateTool()}" source="com/esri/solutions/flexviewer/assets/images/icons/i_draw_point.png" useHandCursor="true" buttonMode="true" toolTip="{pointLabel}" width="40" height="40"/>
     <mx:Image click="{clear()}" source="com/esri/solutions/flexviewer/assets/images/icons/i_clear.png" useHandCursor="true" buttonMode="true" toolTip="{clearLabel}" width="40" height="40"/>
    </mx:HBox>
   </mx:VBox>
  </mx:ViewStack>
</WidgetTemplate>
  <!-- End Declarations -->
</BaseWidget>
------------  ReverseGeocode.xml ------------
<?xml version="1.0" ?>
<configuration>
<locator>http://www.vahgis.com/ArcGIS/rest/services/WEB/Address_Locator_MAT/GeocodeServer</locator>
<url>http://www.vahgis.com/ArcGIS/rest/services/WEB/Address_Locator_MAT/GeocodeServer</url>
<zoomscale>2188</zoomscale>
<labels>
  <pointlabel>Locate Address</pointlabel>
  <clearlabel>Clear</clearlabel>
  <descriptionlabel>Click on map to find address of the location:</descriptionlabel>
</labels>
</configuration>
