Flex Example Code Access Problems
1178
01-25-2012 11:00 AM
TylerWaring
Greetings Everyone,
          I am having issues accessing the code Flex examples at the ArcGIS Resource Center. When I click on the Source Code tab for any example, the applicaiton covers half of the the content in the tab. This makes fully accessing the code difficult if not alltogeher impossible. Is anyone else having a problem? I am desperatly trying to access the source code for the Editing examples (http://help.arcgis.com/en/webapi/flex/samples/index.html#/Default_Editor/01nq0000001r000000/) .
Any tips or tricks will be greatly appreciated.
Tyler
RobertScheitlin__GISP
Tyler,
   I have never seen that before have you tried a different browser (i.e. if you are using Chrome use FireFox)?
ReneRubalcava
Esri Frequent Contributor
Odd. I just tried the link you posted and get the same thing in IE Version 8.0.6001.18702
Works fine in Chrome.
I haven't looked at the Flex samples pages in ages, never noticed it before.
TylerWaring
That is the version I use as well. I installed a different browser and it worked fine.
TracySchloss
Honored Contributor
I've experienced a similar problem myself.   The source does display, but the scrollbar that comes up doesn' really scroll through the entire set of code.
I remembered that all the samples were included in the API download and I've just been going there instead.
