Flex API Identify results attributes come back in random order
2460
06-07-2010 01:33 PM
JacksonTrappett
I added the identify tool to my flex app (1.3 API) using code similar to the Identify widget in the sample viewer, and I have been having an issue where the fields are always returned in a random order.  The order that the fields appear in the rest endpoint is what I'd like them to display as in the identify results.
When I submit an identify request to the service through the rest endpoint, it always returns the fields in the same order.  When I get the results using the identify code supplied by the Flex api they are always in a random order that changes each time you open the flex app.
Is there a setting I can change in my flex code that will fix this or is it the API that does this?  If it is in the API, is that considered a bug or a feature?  Anyone know whether it still behaves in this manner in the new 2.0 api?
Thank you!
RoyceSimpson
This is a known issue with the 1.x APIs.
As of 2.0 Beta Update 3, they still seem to come out in random order, unfortunately.
