Flex API Calendar Instead of Time Slider
772
05-23-2012 08:07 PM
ShaunWeston
I have a map service, which is time enabled and I would like to build some flex code, so that users can query this map service by changing the day on a calendar as opposed to using the out of the box time slider. Just wondering if anyone has done this before and how hard it would be to do?
tanyabisen
Hello Everyone,
I am trying to build a Time Slider on a similar approach, wherein I want to customize the Time Slider in Flex API. When i select the date range and play the Time slider it should work.
I have little idea of how to proceed about it  but if someone can share their tips it will be beneficial for me. e.g. When I select the date range how it will query my map service and how the time stops can be created so that my time enabled layer recognizes it and works.
Thanks and Regards,
Tanya
