Flex API 2.0 error when using custom component library projects
1201
06-29-2010 07:30 AM
ReneRubalcava
Esri Frequent Contributor
I have an odd error creeping up on me with the 2.0 final release.
I have a component library that I use with my projects that's been updated with the 2.0 API.
When I add this library project via FlashBuilder, I get an error in the SkinnableComponent.as line 632 in my main Application.
I tried adding this Library Project to some samples and added a custom "MapLayerList" component and got the same error, but when added as a compiled swc, works fine.
Error: Skin for FeatureLayer_Search.ApplicationSkin2._ApplicationSkin_Group1.contentGroup.myMap.StaticLayer11.ScaleBar66 cannot be found.
I don't even need to add a component to the project, just add the Library project. So, I'm not sure why the issue persists.
I had this problem with the beta 2, but it went away with the beta 3, so I figured it was a byproduct of some fixes/changes you made. If I compile my Library project to a swc and use it, everything works fine. So, I'm not sure if this an issue with FlashBuilder or not. I have not had a chance to test it in FDT or IntelliJ yet.
Is anyone able to replicate this problem in FlashBuilder?
Here is an example of how I use Map in custom components
MapLayerList
http://gist.github.com/457363
It's not a deal breaker, but it's nice to modify my Library and see instant results without constant recompiles.
DasaPaddock
In your library project's Library Path where you've included the ArcGIS API for Flex swc, did you set it's Link Type to External? The default is "Merged into code".
ReneRubalcava
That was the right direction. Setting the library project to external caused some other issues, but setting it to an RSL fixed it right up.
Thanks for another solid release!
