Flex 4.1 SDK Warning with FlexViewer 2.1
12127
24
09-23-2010 06:43 AM
RobertScheitlin__GISP
API Team,
   I get this warning when using FLEX SDK 4.1
Description    Resource    Path    Location    Type
com.esri.viewer:BaseWidget is a module or application that is directly referenced. This will cause com.esri.viewer:BaseWidget and all of its dependencies to be linked in with index. Using an interface is the recommended practice to avoid this.    flexviewer2.1        Unknown    Flex Problem
Any comments on this one?
Mark,
   GREAT JOB! this works pointing to the 4.0 SDK as well.
HugoMaurício
Hi.
Finally solved the problem. Here's how.
In the Project Properties Window - > Flex Compiler Tab -> Addicional compiler arguments: Changed from "-locale=en_US ..." to "-locale en_US...". So, I removed the equals character.
The full arguments line is
"-locale en_US -source-path=locale/{locale} -keep-all-type-selectors=true"
Hugo Maurício
DavidMarley
I was having the same issue with the design time errors (in my case with ESRI Flex 2.2 and Flash Builder 4), and Hugo's fix did the trick for me (i.e., removing the equal sign, so from "-locale=en_US ..." to "-locale en_US..." ).
Thanks for posting Hugo!
FredericSchettini
I also experienced the following error : Unable to resolve resource bundle "ESRIMessages" for locale "en_US"
The marktorrey bypass gave me the way : "manually adding the Flex SDK Locale(en_US) to the projects build path."
The sources where put on an UNC driver (sort of \\servername\directory$\Sources
I just move the source to a local directory : C:\Local\Sources
=> The errors then disapeared
JeffPerkins
I'm using Flexapi 2.2 and getting "unable to open 'locale/en_US' error.
I've adding additional compilier argument:
In addition, I've "manually adding the Flex SDK Locale(en_US) to the projects build path"
Any info on this...
