Flex 2.4 Renders KML KMZ layers off by 3000 km
1025
01-23-2013 07:32 AM
stevemclaughlin
Hi, take the Flex api example 'Layers/Basic KML Layer'
http://resources.arcgis.com/en/help/flex-api/samples/#/Basic_KML_Layer/01nq00000079000000/
and run it, the layer is centered over the
US, take the same code and replace the arcgis lib with the 2.4 version 'agslib-2.4-2011-07-25.swc'
run it again without any code changes and the kml layer is about 3000 km south - now covering central america.
Loading the kmz file into google earth, shows the layer covering the US, so the example running with the Flex 3.0 lib
shows the correct translation.
Just curious is the error in rendering caused by the kmz service utility or ??
thanks,
steve
BjornSvensson
Esri Alum
Flex 2.4 Renders KML KMZ layers off by 3000 km .... Flex 3.0 [is] correct...
If it's fixed in a later API version then it's probably not the utility service.
It might have been fixed in version 2.5:
* Improved KML support
http://resources.arcgis.com/en/help/flex-api/concepts/index.html#/What_was_new_in_ArcGIS_API_for_Fle...
stevemclaughlin
Thanks, I was looking for that doc,  that must be it, under Bug Fixes for Flex 2.5:
* Map images in KML layers placed correctly
