Flash 10.2 Update - Debug Problems
876
03-14-2011 05:18 AM
PeterMcAlenney
HI,
I just installed the Flash 10.2 players and and using Flash Builder 4 with the Flex 4.1 SDK that comes with it.  I can play my flex projects, but can't debug.  So it did the usual download/install of the debug players, which usually fixes it.  But Flex complains it can't find the playergloabl.swc in the 4.1 SDK folder...  Found on google that i need to have the Flex 4.5 Hero SDK installed - which i tried to do, but still won't debug.  Also read on the google that Flash Builder 4 only supports up to flash 10.1!!!
Can anyone shed some light on how to deal with this?!  I need to debug my flex apps, or revert back to the 10.1 version of flash - tried to do that, but could not download that version from Adobe?!
Pete
DasaPaddock
You can get older versions of the Flash Player at:
http://kb2.adobe.com/cps/142/tn_14266.html
You should be able to use 10.2 with Flex SDK 4.1. Flash Builder also should work fine when using SDK 4.5 which requires Flash Player 10.2. It may just be a project settings issue. I'd try creating a new test project and see if it's working fine there.
