FindTask 1000 point limit
1046
10-19-2011 07:01 AM
AdrianHughes
I'm running a findtask query on a large point layer. It seems a maximum of 1000 points can be returned. Is this a limitation of the flex api or is there a setting to change this?
BrandonCopeland
By default, map services return a maximum of 1000 features. This configuration can be changed from the Parameters tab of the Map Service Properties in either ArcCatalog or ArcGIS Server Manager.
AdrianHughes
I changed the setting and its now working, thanks!
