FindParameters.searchText wild card?
3865
6
12-10-2010 11:38 AM
PaulSchneider
I'm having success with the FindParameters class, but am finding a limitation in what I am able to use for the .searchText property.
For instance:
findParams.searchText = "John Smith" //does NOT find a value of 'John A Smith'
Is there a wild card character or operator syntax that I could add that would return a result as such?
Maybe something like...
findParams.searchText = "John%%Smith" or
findParams.searchText = "John AND Smith"
Thanks-
SandeepKapadia
Did you find a solution for your issue? I'm facing similar situation.
BjornSvensson
Esri Alum
Is there a wild card character or operator syntax that I could add that would ... Maybe something like...
No, "Find" does not support wildcards within search strings like that.  You would have to use Query.  Though remember that Find works on a MapService and Query on individual layers.
SandeepKapadia
Thank you.
I have a different question, Can I search on different fields in a single query? Meaning, search for field1 = 'Value1', field2 = 'Value2', etc?
findParameters.SearchFields.AddRange( new string[] {field1, field2});
findParameters.SearchText = Value123;
But I need to search multiple values, how can I do that?
Sandeep
BjornSvensson
Esri Alum
You can search for the same string in multiple fields using "Find" but I don't think that is what you are aiming for.
To search for multiple strings you either send multiple "Find" requests, or you can send a single "Query" (if it's only on one layer).
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/tasks/supportClasses/Query.html
aubinmaynard
I'm stumbling through learning coding, and need to do such a multiple search.  Any chance I can see a complete example of some working code using the query function?
A
MichaelVolz
Esteemed Contributor
Does this wildcard limitation still exist with the Find Task?
