featureset value.
4797
05-15-2015 11:09 AM
EvelynHernandez
Hello,
I have this code and idk why i cannot get the "zoom" value for the query.
function onResult(featureSet:FeatureSet, token:Object = null):void
  try{
  var mapPoint:MapPoint = featureSet.features[0].geometry as MapPoint;
  var convert:ConvertCoords = new ConvertCoords;
  convert.ToGeographic(mapPoint.x,mapPoint.y);
  lat = convert.Y_lat;
  long =convert.X_lon;
  map.zoomTo(featureSet.features[0].geometry);
  //Alert.show("punto: " + mapPoint.x.toString() + " "  +mapPoint.y.toString()+ " "+  "lat: " + convert.Y_lat.toString()+ " "+convert.X_lon.toString() );
  map.level = 16;
  zoom = featureSet.features[0].attributes["zoom"];
  Alert.show(zoom.toString());
  }catch(err:Error){
  Alert.show("no");
  function onFault(info:Object, token:Object = null):void
  Alert.show("not found");
Mensaje editado por: Evelyn Hernandez
EvelynHernandez
i found my problem. I was using another layer and it doesnt have the "zoom" field
Thanks robert
RobertScheitlin__GISP
Evelyn,
   Your zoom attribute is all upper case in your service so code needs to be as well
zoom = featureSet.features[0].attributes["ZOOM"];
EvelynHernandez
i receive a NaN, what can be the issue?
Evelyn,
   What do you receive when you do this on one of the 3 records that does not have a null as its value in your data?
EvelynHernandez
I receive a NaN value. I know that i have some null values , but "PLACILLA" has a zoom value.
I dont know why i cannot get it.
EvelynHernandez
Thanks robert
