Features From Feature Layer
4353
7
02-01-2011 08:34 AM
sreeharikottoormadam
How to get the features from the feature layer and add as a graphic layer?
I have a featurelayer . While loading the map, all the points in that feature layer should add as a graphic layer with attribute information.
Thanks!
DasaPaddock
protected function jnjMap_loadHandler(event:MapEvent):void
    //Add feature layer to the map
    var fLayer:FeatureLayer=new FeatureLaye("http://sampleserve1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapS...");
    jnjMap.addLayer(fLayer);
This is working for me. but i need to add this layer as a grahic layer with attribute value(any one or two fields of the feature layer).
By this code I can add graphics from a feature layer and render with my own symbols. is it the correct method (limited query feature(max. 500) and performance)?
Actually I need to get the attribute value from the feature insted of taking the value from the graphic.
protected function XYZMap_loadHandler():void
    // TODO Auto-generated method stub
    this.cursorManager.setBusyCursor();
    //clear
    myGraphicsLayer.clear();
    //load graphic
    var uniqueID:String;
          var queryTask:QueryTask = new QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/Map...");
    queryTask.useAMF = false;
    var query:Query = new Query();
    query.where ="1=1"
    query.outSpatialReference = jnjMap.spatialReference;
    query.returnGeometry = true;
    query.outFields = [ "STATE_NAME" ];
    queryTask.execute(query, new AsyncResponder(onResult, onFault));
    function onResult(featureSet:FeatureSet, token:Object = null):void
     for each (var myGraphic:Graphic in featureSet.features)
      uniqueID=myGraphic.attributes.STATE_NAME;  //Get State name to a variable
      myGraphic.toolTip=myGraphic.attributes.CITY_NAME;
      if (uniqueID=="Washington"){
       myGraphic.symbol = mySymbol;
      else {
      myGraphic.symbol = defaultSymbol;
      myGraphicsLayer.add(myGraphic);
    function onFault(info:Object, token:Object = null):void
     Alert.show(info.toString());
    this.cursorManager.removeBusyCursor();
plz help me.......   is there is any alternate method to do this?
RobertScheitlin__GISP
Sreehari,
   You really need to read the documentation on FeatureLayer... A featurelayer inherits from graphicslayer. It basically is a enhanced graphics layer that DOES have attributes because it does a querytask internally. You should be able to do every thing you are after just using the featurelayer.
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/layers/FeatureLayer.html
can u plz share any code for doing the same....
I am new to flex...
Sreehari,
   We all started as new to flex. That is why there are samples on the Flex API page.
http://help.arcgis.com/en/webapi/flex/samples/index.html?sample=FeatureLayer_MouseOver_Snapshot
Dear Robert Scheitlin,
                                   I have gone through the samples. Actually my requiremnt is bit different. I need to add afeature layer as graphic by looping each feature and  add an attribute(eg Uniq Id) to it. based on  that attribute value (uniqid), need to access values from sql server and render it.
thank you.....
