FeatureLayer MouseOver vs NavigationTool
890
03-25-2011 10:00 AM
GlenReid
I added a very simple navigation bar to the InfoWindow on MouseOver sample.
On load, the featureLayer mouseOver events work fine.  When navigation is activated (by any tool), the mouseOver events fail to work.  Once navigation is deactivated, the MouseOver events work again.
Test case:
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark"
      xmlns:mx="library://ns.adobe.com/flex/mx"
      xmlns:esri="http://www.esri.com/2008/ags"
      pageTitle="FeatureLayer - show InfoWindow on mouseOver">
 This sample shows you how to display an InfoWindow on a mouse over ("map tips").
 The 46 South Carolina counties are all fetched from the server using the
 'snapshot' mode and drawn clientside.  As the mouse moves over a county,
 an infoWindow will show as a 'map tip'.
 <fx:Script>
  <![CDATA[
   import com.esri.ags.Graphic;
   import com.esri.ags.SpatialReference;
   import com.esri.ags.events.GraphicEvent;
   import com.esri.ags.geometry.Extent;
   import spark.events.IndexChangeEvent;
   protected function fLayer_graphicAddHandler(event:GraphicEvent):void {
    event.graphic.addEventListener(MouseEvent.MOUSE_OVER, onMouseOverHandler);
    event.graphic.addEventListener(MouseEvent.MOUSE_OUT, onMouseOutHandler);
   private function onMouseOverHandler(event:MouseEvent):void {
    var gr:Graphic = Graphic(event.target);
    gr.symbol = mouseOverSymbol;
    myTextArea.htmlText = "<b>2000 Population: </b>" + gr.attributes.POP2000.toString() + "\n"
     + "<b>2000 Population per Sq. Mi.: </b>" + gr.attributes.POP00_SQMI.toString() + "\n"
     + "<b>2007 Population: </b>" + gr.attributes.POP2007 + "\n"
     + "<b>2007 Population per Sq. Mi.: </b>" + gr.attributes.POP07_SQMI;
    myMap.infoWindow.label = gr.attributes.NAME;
    myMap.infoWindow.closeButtonVisible = false;
    myMap.infoWindow.show(myMap.toMapFromStage(event.stageX, event.stageY));
   private function onMouseOutHandler(event:MouseEvent):void {
    gr.symbol = defaultsym;
    myMap.infoWindow.hide();
   private function zoomToSouthCarolina():void {
    var southCarolinaExtent:Extent = new Extent(-9294000, 3667000, -8739000, 4217000, new SpatialReference(102100));
    myMap.extent = southCarolinaExtent;
    // make sure the whole extent is visible
    if (!myMap.extent.contains(southCarolinaExtent)) {
     myMap.level--;
   private function tbbChangeHandler(event:IndexChangeEvent):void {
    switch (tbb.selectedItem) {
     case "Zoom In": {
      navTool.activate(NavigationTool.ZOOM_IN);
      break;
     case "Zoom Out": {
      navTool.activate(NavigationTool.ZOOM_OUT);
      break;
     case "Pan": {
      navTool.activate(NavigationTool.PAN);
      break;
     default: {
      navTool.deactivate();
      break;
 </fx:Script>
 <fx:Style>
  @namespace s "library://ns.adobe.com/flex/spark";
  @namespace mx "library://ns.adobe.com/flex/mx";
  @namespace esri "http://www.esri.com/2008/ags";
  @namespace components "com.esri.ags.components.*";
  components|InfoWindow {
   content-background-alpha : 0;
   background-color : yellow;
   background-alpha : 0.8;
   border-style : solid;
 </fx:Style>
 <fx:Declarations>
  <esri:NavigationTool id="navTool" map="{myMap}"/>
  <esri:SimpleFillSymbol id="mouseOverSymbol" alpha="0.5">
   <esri:SimpleLineSymbol width="0" color="0xFF0000"/>
  </esri:SimpleFillSymbol>
  <esri:SimpleFillSymbol id="defaultsym" alpha="0.2">
   <esri:SimpleLineSymbol width="0" color="0xEEEEEE"/>
 </fx:Declarations>
 <s:layout>
  <s:VerticalLayout/>
 </s:layout>
 <s:HGroup width="100%" paddingTop="5" paddingLeft="5" paddingRight="5">
  <s:ButtonBar id="tbb" change="tbbChangeHandler(event)">
   <s:ArrayList>
    <fx:String>Zoom In</fx:String>
    <fx:String>Zoom Out</fx:String>
    <fx:String>Pan</fx:String>
    <fx:String>Deactivate</fx:String>
   </s:ArrayList>
  </s:ButtonBar>
 </s:HGroup>
 <esri:Map id="myMap" load="zoomToSouthCarolina()">
  <esri:infoWindowContent>
   <mx:TextArea id="myTextArea" width="250" height="75"/>
  </esri:infoWindowContent>
  <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/>
  <esri:FeatureLayer id="fLayer"
         definitionExpression="STATE_NAME='South Carolina'"
         graphicAdd="fLayer_graphicAddHandler(event)"
         mode="snapshot"
         outFields="*"
         symbol="{defaultsym}"
         url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/3"/>
 </esri:Map>
 <s:Label width="100%" enabled="{fLayer.loaded}"
    text="The {fLayer.numGraphics} South Carolina counties are all fetched from the server using the 'snapshot' mode and drawn clientside.  As the mouse moves over a county, an infoWindow will show as a 'map tip'."/>
</s:Application>
Is there a way to avoid this?
Glen
RobertScheitlin__GISP
Glen,
   It is pretty simple just add true for EnableGraphicsLayerMouseEvent on the navTool.activate.
navTool.activate(NavigationTool.ZOOM_IN, true);
GlenReid
Simple indeed.  Thanks Robert.
