error:[RPC Fault faultString="Unable to complete operation..] intersect widget
3212
04-07-2014 01:31 PM
by Anonymous User
Not applicable
Original User: zanady
Hi everyone,
I am trying to develop a intersection widget  using the geoprocessing service.
my geoprocessing service is as follows:
[ATTACH=CONFIG]32889[/ATTACH]
[ATTACH=CONFIG]32890[/ATTACH]
I try to  consomer this service in my flex application this  is my code:
<?xml version="1.0" encoding="utf-8"?>
// Copyright (c) 2010-2011 Esri. All Rights Reserved.
// Licensed under the Apache License, Version 2.0 (the "License");
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at
//    http://www.apache.org/licenses/LICENSE-2.0
// Unless required by applicable law or agreed to in writing, software
// distributed under the License is distributed on an "AS IS" BASIS,
// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
// See the License for the specific language governing permissions and
// limitations under the License.
<viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009"
                   xmlns:s="library://ns.adobe.com/flex/spark"
                   xmlns:mx="library://ns.adobe.com/flex/mx"
       xmlns:esri="http://www.esri.com/2008/ags"
       xmlns:viewer="com.esri.viewer.*"
       xmlns:components="com.esri.viewer.components.*"
       creationComplete="init()">
    <fx:Script>
        <![CDATA[
   import com.esri.ags.FeatureSet;
   import mx.rpc.events.FaultEvent;
   import mx.collections.ArrayCollection;
   import mx.controls.Alert;
   import mx.managers.CursorManager;
   import com.esri.ags.layers.GraphicsLayer;
   import mx.rpc.AsyncResponder;
   import com.esri.ags.tasks.supportClasses.ExecuteResult;
   import com.esri.ags.tasks.supportClasses.ParameterValue;
      private var intersectLyrLen:int;
   private var msgVisible:Boolean = false;
   public var graphiclayer:GraphicsLayer=new GraphicsLayer();
   private function init():void
    graphiclayer=new GraphicsLayer();
    graphiclayer.symbol= intersectSimpleFill;
    map.addLayer(graphiclayer);
   private function intersectIfOptionsValid():void
    var hasAreaSelected:Boolean = (map.defaultGraphicsLayer.numGraphics > 0);
    var hasSelectedLayersTointersect:Boolean = pointsCheckBox.selected || lignesCheckBox.selected || Mar_adm1CheckBox.selected ||Mar_adm2CheckBox.selected ||Mar_adm3CheckBox.selected ||Mar_adm4CheckBox.selected ;
    if (hasAreaSelected && hasSelectedLayersTointersect)
     intersectdata();
    else
     showErrorMessage("Select layers to intersect");
   private function showErrorMessage(content:String):void
    Alert.show(content, "Geoprocessing Task Error");
   private function intersectdata():void
    var requestObject:Object = createRequestObject();
    gp.execute(requestObject,new AsyncResponder(onResult, onFault));
    function onResult(gpResultat:ExecuteResult=null,token:Object=null):void
     var pv:ParameterValue = gpResultat.results[0];
     var fs:FeatureSet = pv.value as FeatureSet;
     graphiclayer.graphicProvider=fs.features;
     intersectLyrLen = graphiclayer.numGraphics;
     msgVisible = true;
    function onFault(info:Object,token:Object=null):void
     Alert.show(info.toString());
     graphiclayer.clear();
   private function createRequestObject():Object
    var layers1Tointersect:Array = getLayers1tointersect();
    var layers2Tointersect:Array=getLayers2tointersect();
    var requestObject:Object = {
     "points ": layers1Tointersect,
     "Mar_adm4": layers2Tointersect
    return requestObject;
   private function getLayers1tointersect():Array
    var layers1Tointersect:Array = [];
    if (pointsCheckBox.selected)
     layers1Tointersect.push(pointsCheckBox.label);
    if (lignesCheckBox.selected)
     layers1Tointersect.push(lignesCheckBox.label);
    if (Mar_adm1CheckBox.selected)
     layers1Tointersect.push(Mar_adm1CheckBox.label);
    if (Mar_adm2CheckBox.selected)
     layers1Tointersect.push(Mar_adm2CheckBox.label);
    if (Mar_adm3CheckBox.selected)
     layers1Tointersect.push(Mar_adm3CheckBox.label);
    if (Mar_adm4CheckBox.selected)
     layers1Tointersect.push(Mar_adm4CheckBox.label);
    return layers1Tointersect;
   private function getLayers2tointersect():Array
    var layers2Tointersect:Array = [];
     layers2Tointersect.push(pointsCheckBox.label);
     layers2Tointersect.push(lignesCheckBox.label);
     layers2Tointersect.push(Mar_adm1CheckBox.label);
     layers2Tointersect.push(Mar_adm2CheckBox.label);
     layers2Tointersect.push(Mar_adm3CheckBox.label);
     layers2Tointersect.push(Mar_adm4CheckBox.label);
    return layers2Tointersect;
   private function clearintersect():void
    intersectLyrLen = 0;
    </fx:Script>
<fx:Declarations>
 <esri:SimpleFillSymbol id="intersectSimpleFill"
         alpha="0.5"
         color="0xFF0000">
  <esri:SimpleLineSymbol width="1"
          alpha="0.5"
          color="0x000000"/>
 </esri:SimpleFillSymbol>
 <esri:Geoprocessor id="gp"
        outSpatialReference="{map.spatialReference}"
        url="http://localhost:6080/arcgis/rest/services/Geotraitement/intersection/GPServer/intersect"
        useAMF="false"/>
</fx:Declarations>
    <viewer:WidgetTemplate id="helloWorld"
                           width="300" height="300">
  <s:Label x="26" y="23" text="Intersection entre deux couches :"/>
  <s:CheckBox id="pointsCheckBox" x="62" y="57" label="points"/>
  <s:CheckBox id="lignesCheckBox" x="62" y="83" label="lignes"/>
  <s:CheckBox id="Mar_adm1CheckBox" x="62" y="109" label="Mar_adm1"/>
  <s:CheckBox id="Mar_adm2CheckBox" x="62" y="135" label="Mar_adm2"/>
  <s:CheckBox id="Mar_adm3CheckBox" x="62" y="161" label="Mar_adm3"/>
  <s:CheckBox id="Mar_adm4CheckBox" x="62" y="187" label="Mar_adm4"/>
  <s:Button x="115" y="233" label="executer" click="intersectdata()"/>
  <s:Button x="202" y="264" label="clear" click="clearintersect()"/>
    </viewer:WidgetTemplate>
</viewer:BaseWidget>
When I execute the widget  an error message appears:"[RPC Fault faultString="Unable to complete operation." faultCode="400" faultDetail="Erreur d�??exécution de l�??outil."]"
I am beginner  can i guide me?
by Anonymous User
Not applicable
Please help me 😞 😞 😞 😞
