Enhanced Search 2.5.0.8.-Image hyperlink in Search Result display same images.
2420
5
01-06-2012 05:32 AM
HeenaLee
Hi Robert,
I have image hyperlink set up in Search Result and Grid Result for Signs data. Most Sign data search is using domain. I am using 2.5.0.8. When search result comes, they display same images. Although when I click image link in Grid field, it displays the correct images. I am attaching image and text file. Could you please help me out? Thank you so much.
RobertScheitlin__GISP
Henna,
   Wrong forum. In the future make sure you post here for Flex Viewer questions:
http://forums.arcgis.com/forums/111-ArcGIS-Viewer-for-Flex
It seems there is a significant issue in Version 2.5.0.8 when it comes to my new multi link code. I am working on a fix right now.
by Anonymous User
Not applicable
Original User: rscheitlin
Henna,
   Fix is available in version 2.5.0.9 of the widget to correct this bug.
http://www.arcgis.com/home/item.html?id=5d4995ccdb99429185dfd8d8fb2a513e
Don't forget to mark post as answered.
Heena,
   Did you see that this was fixed?
by Anonymous User
Not applicable
Original User: heena
Robert,
Yes. I am using the updated one. You are the best. I really appreciate your diligent work and contribution to this forum.
Henna,
   It is the checkmark below the <1> that marks the post as answered (the lower red rectangle).
