Editor - Save without need to close the window?
1062
02-10-2014 07:25 AM
ionarawilson1
When  using the editor, is it possible to prevent the attribute inspector info window from being closed but that the edits are saved with the window still open? Thanks
ionarawilson1
Anybody can help me with this question?Thanks
JHayes
Perhaps if you explained why you would want this functionality I could better help with an answer.
Jw
ionarawilson1
Thank you Joseph. I have a geoprocessing service that runs when the user selects the feature and run the tool. But it would be better if the user did not need to select the feature twice but that he could draw the feature, then with the info window open he would save, and then click on a button on the info window to run the gp service. Right now, the feature does not get created until the user closes the window, then he needs to select the feature again and then run the tool. Thank you!
