Edit map signature
2867
08-19-2014 07:41 AM
EvelynHernandez
Hello.
Im wondering how to change this to put a copywrite in my project, also if its possible to put a image on that space.
Thank yuo for all ur support!
RobertScheitlin__GISP
Evelyn,
     That component is called "Attribution" and it gets the text from the current map services copyright attribute. It can be turned off using the Map.attributionVisibile property. It displays text and therefore would have to be heavily modified to be able to do anything with images.
com.esri.ags.components.Attribution
Evelyn,
AnthonyGiles
Honored Contributor
If you want to place an image on your map to display a logo etc the static image widget code from the flex viewer will give you a point in the right direction:
arcgis-viewer-flex/StaticImageWidget.mxml at develop · Esri/arcgis-viewer-flex · GitHub
EvelynHernandez
Yes. I looked it before. I was thinking on implements that widget on my Flex Application but the thing is i just wanted to edit the esri signature to add the signature of the project too.
Thanks anyways for ur reply. I appreciate it too much
