eclipse/flex
3501
04-03-2013 03:45 AM
lifeEsri
hello
I want to know if there's a possibility of working with flex in eclipse,
and if there's a flexviewer for eclipse
thank you in advanced.
IvanBespalov
ArcGIS API ->  Getting Started
section Requirements has all needed links
FlexViewer sources link is on FlexViewer main page
FlexViewer -> Getting started for developers
lifeEsri
Merci
j'ai déja vu ça 🙂
mais mon probleme c'est que je voudrai travailler dans l'environnement eclipse avec j2ee/flex
alors qu'elle sont les possibilitées de dévellopement ainsi que l'architecture d'application convenable à ceci
et merci d'avance
YannCabon
FlashBuilder is built on top of eclipse so you can install J2EE plugins on top of it.
In Eclipse, use the install manager: Help > Install New Software.
brahimmaylal
Hello;
         I have the same problem; I am integrating the flash builder4.6 with eclipse 3.6 for the reason to combinate bitwen The
convivial interfaces in flex with J2EE language for creating the own widgets. 😞
It is possible to do thes or not??
