Dynamic Rest Legend in ArcGIS Server 10 and Flex API 1.3
9973
28
08-13-2010 07:26 AM
JasonHancheruk
I just upgraded ArcGIS Server to version 10 from 9.3.1. When I open the Flex page through the browser, instead of the dynamic legend loading, the wait for legend creation just keeps spinning.
Is there a way to fix this problem?
JasonHancheruk
Update.
It appears the error shown in the previous post only happens when initially opening the Flex page. To test, I opened the application page, then zoomed in (sometimes once, other times twice) and the map legend appeared as normal. Robert, do you have any ideas on the cause?
Thanks.
RobertScheitlin__GISP
Jason,
   Well there is no error in your LiveMapsWidget.mxml as I took it and only changed the url of the wsdl and it worked just fine for me when I used your code in my viewer.
   When you tested the asp.net web service on your server as I mentioned in my previous email did you happen to copy one of the image urls and test to see if it displayed and image when you put it in a browser?
   Also have you put http://AFR112PROD4/restLegend/restLegend.asmx?wsdl in a browser and seen it bring up the wsdl file for your to see?
Shaf,
   The file is not damaged this is a known issue with this forum when you try to use Internet Explorer to download a zip file. Try and use Firefox or Google Chrome instead. Also be warned that this is not something that is easy to implement even for a non-beginner in Flex.
JasonHancheruk
Hi Robert. Yes I did test to see if the image came up, and I had no problems connecting to any of them in the xml. Since they always work, but not right away, could it be a timing issue where the legend request is timing out before the app gets a chance to populate the legend?
JasonHancheruk
Hi Robert. Is there anyway to pause the creation of the Legend? When I look at the error through Fiddler (below), I am thinking the legend is trying to start before the server is ready.
Yes/No, any help would be great.
<?xml version="1.0" encoding="utf-8"?><soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><soap:Body><soap:Fault><faultcode>soap:Server</faultcode><faultstring>Server was unable to process request. ---&gt; The request failed with HTTP status 404: Service Not Found or Not Started.</faultstring><detail /></soap:Fault></soap:Body></soap:Envelope>
Jason,
   You have your LiveMapsWidgets coming up with the legend from the start right? Can you instead have it open to the TOC and then let the user switch to the legend?
JasonHancheruk
Ignore the the last post. It was the aerial imagery in a map service.
Sorry, forgot about that issue.
http://forums.esri.com/Thread.asp?c=158&f=2421&t=299116
JasonHancheruk
Hi Robert.
I have been playing around with the dynamic legend, and I am still getting the error. The error only happens the first time I open the legend, and hitting the browser refresh button fixes it.
If I remove the service that contains the rasters (from the config file), the problem does not appear at all. This does include adding the raster service to code as mentioned in the previous post.
I am wondering if you have any ideas on why this may be happening?
Jason,
   Rasters can not be part of a map service that you are generating a legend for. That is just a limitation of the code. I have advised others in the past to just separate out raster layers to their own map service and then exclude them from the legend code.
JasonHancheruk
I have three different services opening, with one containing rasters. I don't remember the forum where you showed how to remove the specific service layer from the legend.
