Dynamic Lables and the Locate Widget
808
02-21-2011 07:01 AM
MartinSiwek
I have a map service that is dynamically labeled as remove duplicate labels.  When I use the locate widget while this map service is on; the resulting red circle is placed directly on top of my label.  I've adjusted the extent properties of the locate widget, but this has not helped.  Is there a way to get around this in either the locate widget, or the map document that I am running my service from?
Thanks!
-Martin
